Three x Three Centre Aligned PWM
A project log for Triple Brushless Actuator - ESP32
3x DRV8313, 6x SPI/I2C Encoders, 3x Current, Voltage, FET Temp, 2x UART, USB, (CAN), 2x I2C, OLED. Core 1 BLDC control. Core 0 Arduino.
paul-gouldPaul Gould 06/27/2021 at 03:120 Comments
9 PWM from ESP-32
The first 6 are centre aligned together
The second 3 are centre aligned together with a 180degree offset to smooth out the power fluctuations.
Ideally they should be 3 each at 120degrees apart but the there are only two MCPWM blocks (with 6PWM each) and I cannot work out how to sync between them.
