Audio and PS/2 port testing
A project log for Neotron Pico
A microATX motherboard that uses a Raspberry Pi Pico as the CPU. SuperVGA output, stereo audio, a BIOS written in Rust and not much RAM!
jonathan-thejpster-pallantJonathan 'theJPster' Pallant 09/29/2022 at 11:260 Comments
In the last post I referred to some testing of the Audio CODEC using CircuitPython. Here's a video showing the code, with the Neotron audio in the background.
I also should mention that the PS/2 keyboard is being received on the BMC chip correctly, but work continues on getting data from the BMC to the main RP2040. Comms is working, but only at around 1 MHz currently. Here's a video showing programming the BMC, keycodes being sent to the laptop over the debug log, and the PC Speaker doing a short beep for every keypress.
