Updated Process 01 documentation to v1.1.
Updated solutions long term storage information.
Switched to using acetone for stripping photoresist (step 24), as suggested by @HennerZeller on youtube.
Added a note regarding sludge formation to step 11.
https://hackaday.com/2021/06/11/open-source-method-makes-possible-two-layer-pcbs-with-through-plating-at-home/
@Luke: In these two years I have not done much improvement to the process, I only just used it as-is to make some more PCBs, but I was keeping track of the various solutions to update the guide with information about the long-term storage of the solutions.
What may be interesting to you, is that after about two years of storage in a well capped container, my palladium activator solution turned from dark brown to pale yellow, and when it did, it stopped working. The pale yellow solution leaves a brown coating on the PCB copper that is not catalytic towards the electroless copper solution, and the same brown coating cannot be easily removed, making it necessary to restart from scratch with a new PCB.
If I find some time I will explore more the chemistry of the palladium solution, but the TL;DR is that if your palladium solution is pale yellow it does not work, while if it is dark brown it works. This can also be used as a clear visual indicator that the solution has gone bad.
I updated the Process 01 document with this information.
