This project intends to build an easy-to-use installer for getting started with the Raspberry Pi Pico microcontroller board (and perhaps other RP2040 Chip-based boards) on Windows (using the C/C++ SDK). It is based on the pico-setup project for Linux computers and is basically comparable to it.
Download Latest Pico Setup for Windows
As described in the official Getting started with Raspberry Pi Pico, the installers automate the required installation on Windows. Additionally, the installer provides the option to clone and build the Raspberry Pi Pico SDK for C/C++, as well as other associated repos that may be beneficial.
The installers make an effort to quietly instal the needed tools without user involvement. The installers are set up using the official guide's suggested choices. Advanced users who want to tweak the programme themselves may find it easier to download and instal it manually or with the help of a package manager.
Software that is Included:
- GNU Arm Embedded Toolchain - the official guide refers to this as "ARM GCC Compiler"
- CMake
- Build Tools for Visual Studio 2019
- Python 3.9
- Git for Windows
- Visual Studio Code
- OpenOCD with picoprobe support
- Zadig
- Doxygen
- Graphviz
NSIS 3 is used to create the installers. When a JSON configuration file is supplied to build.ps1, it generates the NSIS script. The build script downloads a local copy of NSIS to utilise for the build automatically.
There are configuration files for both x86 (32-bit) and x64 (64-bit) builds. MSYS2 must be installed before OpenOCD can be compiled. A local copy of MSYS2 is automatically downloaded and installed by the build procedure. The -MSYS2Path option allows you to give a path to an existing copy of MSYS2. If this location does not already have a copy of MSYS2, the build script will instal one.
It is strongly advised that you utilise a separate copy of MSYS2 for this build.
To construct:
.\build.ps1 .\x64.json -MSYS2Path ~\Downloads\msys64 .\build.ps1 .\x86.json -MSYS2Path ~\Downloads\msys64
The bin directory will hold the produced installers.
Visit: GitHub For Pico Setup for Windows
Posts You May like:
- Using micro-ROS on the Raspberry Pi Pico
- LED Tricks Using The Raspberry Pi Pico
- The RP2040 Raspberry Pi Pico Meets LoRa
- Pico supports SD cards and FatFS
- How to connect a Raspberry Pi Pico to LoRaWAN
- 50 Raspberry Pi Hacks & Tips You Should Know
- How to Install Wi-Fi and Internet on a Raspberry Pi Pico
- Easiest Way to to Run DC Motor with Raspberry Pi Pico
- Drag-and-Drop Programming For The Raspberry Pi Pico
- Make Pico DIY Project Without Any Soldering or Breadboard
- Detailed Comparison of Arduino Nano RP2040 Connect Vs Raspberry Pi Pico
- Make a USB Microphone Using the Raspberry Pi Pico
- The RP2040 is Now Available for $1
- Pico LoRa Expansion is Finally Out! Supports 868MHz
- CircuitPython 6.3.0 is Now Available with Improvement & Fixes
- Pico DIY Projects! Must Try 17 Different Pico HATs & Expansions
Arnov Sharma
