One of the things we introduced in V2 is an additional footprint that allows using a Line Filter that is currently available instead of the original part used by Commodore, which was probably a custom one.
The drawing provided by the manufacturer left something to be desired, so I had to guess some dimensions. After receiving the actual parts Edoardo did a test fit and luckily it seems we got it correct.
