Debug Update!
A project log for NASA Standard Spacecraft Computer-1 (NSSC-1)
Documentation for the NSSC-1 Used on the Hubble Telescope
daves-dev-labDave's Dev Lab 06/27/2021 at 03:180 Comments
NASA has provided some updates to the debug process:
The next steps in the debug process appear to be looking at the Power Control Unit(PCU). The basic information we have about the PCU is:
These voltages are pretty common for computing designs even today, with the exception of the +28 volts. A common ATX power supply provides +5V, -5V, +12V and -12V ( in addition to +3.3V). The PCU is marked in this diagram as A300:
You will notice from the diagram everything seems to be duplicated for redundancy, and several media articles indicate that the PCU has a backup, however none is listed in the diagram or other NASA documentation that I have found.
