Assembly and testing
A project log for Earth globe laser tracker
Track an object with laser on a earth globe
londlond 06/26/2021 at 10:300 Comments
It's time to assembly the unit inside the earth globe...
The screw and nut assembly with a magnet attached simulate the earth globe.
Everything seems to fit, lets power it up..
And now with the earth globe attached..
This was the easy part :) Let the coding of UI and MQTT begin......
