Manufacturing Case
A project log for Coil Winding Machine
To make a machine that winds coil around a steel rod to make an electromagnet.
Jack NajarianJack Najarian 10/09/2015 at 22:490 Comments
I used a cnc router to manufacture the structure of the coil winder out of MDF. At first when I was trying to make sure the program works, I was running the router really slowly. A really fast rpm along with a really slow feed rate caused a small flame.
After that small road block I managed to router out the parts.
Then with some wood glue and dowels I made a sturdy case for my machine.
Now the case is ready for mounting the electronics.
