More FP
A project log for Merlin
68000 Retro Super Computer
Matthew PearceMatthew Pearce 08/16/2021 at 08:300 Comments
I have a 64-bit double precision FPU working now. It seems to be a big improvement on my first version. The main work now is to complete the new library for GCC to make use of the FPU.
I have started to work on a set of wrapper functions which will override the existing soft-float routines.
The first routine overrides muldf3:
double __wrap___muldf3(double a, double b)
  printf("\r\nmuldf3: start\r\n");
  *fpu_ctl = MUL;
  op_a.dbl = a;
  op_b.dbl = b;
  *opa = op_a.num;
  *opb = op_b.num;
  BIT_SET(*fpu_ctl, 0);
  BIT_CLEAR(*fpu_ctl, 0);
  while (!BIT_CHECK(*fpu_sts, 0) && !BIT_CHECK(*fpu_sts, 1))
  resf.num = *fpu_res;
  printf("\r\nmuldf3: stop\r\n");
  return resf.dbl;
It uses a union to convert the double to IEEE754 double-precision int.
union FloatingPointIEEE754
  struct
    unsigned int sign : 1;
    unsigned short int exponent : 11;
    long long mantissa : 52;
  } raw;
  uint64_t num;
  double dbl;
The make file has an additional parameter to override the specified function.
float-test.run: ieee754.c float-test.c
	m68k-elf-gcc -Wall -m68000 -g -Os ieee754.c float-test.c
-Wl,--wrap=__muldf3 -o float-test.run ....
