GUILLENGAP Cobot
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System & 2) Sorting Objects System
Public Chat
VERSION 1...
Robot arm that pick-and-place an object like a box. Here I'm using the "MATRIX Creator" and Raspberry Pi boards, to control a robotic arm by mean of Artificial Intelligence (AI) with voice commands and the "Snips" assistant.
Hi everyone! Below I show you summaries of my Cobot in its three versions:
A video summarizing the journey of this project in the first version. Main goal, Features, Solutions, Content, Hardware and software prerequisites,
guillengap_ver1.zip
First code version of the robot arm
x-zip-compressed - 2.66 kB - 06/27/2021 at 23:09
Download
circuit_diagram.zip
Circuit diagram of the robot arm, version 1
x-zip-compressed - 295.79 kB - 06/28/2021 at 01:11
Download
stl_files.zip
All the STL files necessary to create this project
x-zip-compressed - 11.19 kB - 06/27/2021 at 23:13
Download
datasheets.zip
All the datashhets files used: 1) MATRIX_Creator.pdf, and 2) MG995_Tower-Pro.pdf
x-zip-compressed - 12.30 MB - 06/28/2021 at 00:48
Download
  • 1 × Raspberry Pi 3 Model B+
  • 1 × MATRIX Labs MATRIX Creator
  • 1 × Alexa Echo Dot (3rd Gen)
  • 1 × 6DOF Robot Arm
  • 1 × Micro-USB Cable
View all 10 components
  • Step 9. Test and Conclusion
    Guillermo Perez Guillen06/28/2021 at 02:33 0 comments
    TEST
    Before we start to do tests, we need to do next actions:
    On your Raspberry Pi type node assistant.js
    On your computer's terminal type sam status and sam watch
    Congrats! now you can test your robotic arm
    CONCLUSION
    The prototype worked very well, and is very useful to develop more complex actions with the robotic arm. however, I also had some difficulties such as:
    • The board worked very well with 5 servos and when I used 6 servos the system was collapsed and the robotic arm made strange movements. Also in the servomotor configuration I changed to the value of: min_pulse_ms: 0.2 and the robotic arm worked much better.
    • As I explained at the beginning of this tutorial, I had problems configuring the audio board, but this was successfully solved and now the MATRIX Creator board is very efficient even when it receives keywords at half a meter.
    It's easy to say that in the future this prototype can serve as a model in every home, and may be, we will have a robotic arm at our tables to help us in multiple tasks.
  • Step 8. Printing and Assembling the Panel
    Guillermo Perez Guillen06/28/2021 at 02:27 0 comments
    I have designed a 10 x 10 cm panel for three functions:
    • The first is to hold the cables of the servos and that these don't get disconnected.
    • The second is to hold the connector of all physical grounds of the servos.
    • The third is to hold the connector of all Vcc connections of the servos.
    Below you can see a picture and download the STL file on my GitHub repository here:  https://github.com/guillengap/guillengap-robot-arm
  • Step 7. Wiring the Robot Arm
    Guillermo Perez Guillen06/28/2021 at 02:17 0 comments
    Below you can see the electrical diagram with the connections of this project, it's recommended to do it patiently so as not to make mistakes because there are many cables to be connected.
    I suggest you not wire the servo 5, since in the tests I carried out the system collapsed when I connected the six servos. Then I decided to disconnect the servomotor that was less used.
  • Step 6. Creating assistant.js
    Guillermo Perez Guillen06/28/2021 at 02:15 0 comments
    This step will go show you how to setup a MATRIX Lite project with Snips.
    First, MQTT must be installed and used to listen in on events from Snips.
    npm install mqtt --save
    assistant.js will be used to listen and respond to events from your Snips assistant. This file combines all the code from everloop.js & relay.js to control the everloop and relay switch through voice.
    //AUTHOR: GUILLERMO PEREZ GUILLEN//
    //VARIABLES//
    var mqtt = require('mqtt');
    var client  = mqtt.connect('mqtt://localhost', { port: 1883 });
    var relay = require('./relay.js');
    var everloop = require('./everloop.js');
    var snipsUserName = 'guillengap';
    var wakeword = 'hermes/hotword/default/detected';
    var sessionEnd = 'hermes/dialogueManager/sessionEnded';
    var lightState = 'hermes/intent/'+snipsUserName+':roboticArmState';
    //ON CONNECT//
    client.on('connect', function() {
       console.log('Connected to Snips MQTT server\n');
       client.subscribe('hermes/hotword/default/detected');
       client.subscribe('hermes/dialogueManager/sessionEnded');
       client.subscribe(lightState);
    //ON MESSAGE//
    client.on('message', function(topic,message) {
       var message = JSON.parse(message);
       switch(topic) {
           // * On Wakeword
           case wakeword:
               everloop.startWaiting();
               console.log('Wakeword Detected');
           break;
           // * Robotic Arm Change
           case lightState:
               // Turn robotic arm Here/There
               try{
                   if (message.slots[0].rawValue === 'here'){
                       relay.roboticarmHere();
                       everloop.stopWaiting();
                       console.log('Robotic Arm Here');
                   else if(message.slots[0].rawValue === 'there'){
                       relay.roboticarmThere();
                       console.log('Robotic Arm There');
               // Expect error if `here` or `there` is not heard
               catch(e){
                   console.log('Did not receive an Here/There state')
           break;
           // * On Conversation End
           case sessionEnd:
               console.log('Session Ended\n');
           break;
     everloop.js incorporates the code required to control the LEDs on the MATRIX Creator.
    //VARIABLES//
    const matrix = require('@matrix-io/matrix-lite');
    var matrix_device_leds = 0;// Holds amount of LEDs on MATRIX device
    var methods = {};// Declaration of method controls at the end
    var waitingToggle = false;
    var counter = 0;
    setInterval(function(){
       // Turns off all LEDs
       if (waitingToggle == false) {
               // Set individual LED value
               matrix.led.set({});
       // Creates pulsing LED effect
       else if (waitingToggle == true) {
               matrix.led.set({
                   b: (Math.round((Math.sin(counter) + 1) * 100) + 10),// Math used to make pulsing effect
       counter = counter + 0.2;
       // Store the Everloop image in MATRIX configuration
    },50);
    //WAITING METHODS//
    methods.startWaiting = function() {
       waitingToggle = true;
    methods.stopWaiting = function() {
    module.exports = methods;// Export methods in order to make them avaialble to other files
    relay.js includes the code required to turn the robotic arm here and there. This relay will control power to the robotic arm.
    //VARIABLES//
    matrix.gpio.setFunction(0, 'PWM');
    matrix.gpio.setFunction(1, 'PWM');
    matrix.gpio.setFunction(2, 'PWM');
    matrix.gpio.setFunction(3, 'PWM');
    matrix.gpio.setFunction(4, 'PWM');
    matrix.gpio.setFunction(5, 'PWM');
    matrix.gpio.setMode(0,'output');
    matrix.gpio.setMode(1,'output');
    matrix.gpio.setMode(2,'output');
    matrix.gpio.setMode(3,'output');
    matrix.gpio.setMode(...
  • Step 5. Deploy your Assistant
    Guillermo Perez Guillen06/28/2021 at 02:07 0 comments
    You can now deploy your assistant! On the bottom right of the page will be a Deploy Assistant button.
    Use the Sam CLI Tool to deploy the assistant to your Raspberry Pi. Below is an example of the command to use.
  • Step 4. Adding an Intent
    Guillermo Perez Guillen06/28/2021 at 02:02 0 comments
    Intents are what Snips uses to handle user requests. For this Assistant, we'll start by creating an intent for turning Here/There the MATRIX Creator's App.
    Create a new intent roboticArmState for your RoboticArm app
    Once you've defined your intent, you need to extract whether the user wants their robotic arm here or there. This is where slots come in.
    Create a new slot called power and a custom slot type with the same name.
    Make sure your power slot type has here & there as values.
    Create example sentences containing the words here and there. Highlight these words in your example sentences to assign them to your recently created power slot.
    Be sure to save!
  • Step 3. Creating a Snips Assistant and App
    Guillermo Perez Guillen06/28/2021 at 01:59 0 comments
    Sign into your Snips.ai account.
    Create an assistant called Robotic Arm
    Create an App named RoboticArm
  • Step 2. Connect Sam to Your Raspberry Pi
    Guillermo Perez Guillen06/28/2021 at 01:54 0 comments
    On the command prompt of you Raspberry Pi board type ifconfig to know the IP address of this device
    From your computer's terminal, you can connect to the Raspberry Pi board
    Sign in through the Sam CLI Tool
  • Step 1. Let's Get Started
    Guillermo Perez Guillen06/28/2021 at 01:37 0 comments
    Hardware Prerequisites
    Before getting started, you can check with more details what hardware I used:
    Software Prerequisites
    You can check what required software on my personal computer I used:
    • SD Card Formatter: To easily format our Micro SD Card
    • balenaEtcher: To easily flash our compressed Raspbian Stretch image
    • MATRIX kit image here which includes Stretch + MATRIX packages (2.18 GB)
    • Node.js: Dependancy for Sam CLI Tool (Windows 64 bits)
    • Git Bash: requirement asked by Node.js
    • Snips' Sam CLI Tool: Creates & manages Snip assistants on your Raspberry Pi
    Setting Up the Hardware
    Once everything is well installed on your Raspberry Pi board, You can check the versions of: npm, node and nodejs.
    In my case, I had two serious problems with the configuration of my hardware and these are the solutions:
    FIRST SOLUTION: to activate the pcm.speaker, I had to add a rate of 16000 in the assound.conf file.
    pcm.speaker {
    type plug
    slave {
    pcm "hw:0,0"
    rate 16000
    SECOND SOLUTION: My Raspberry Pi board has better audio with the "portaudio" board, so I had to activate it in the snips.toml file
    [snips-audio-server]
    # frame = 256
    # bind = "default@mqtt"
    mike = "MATRIXIO-SOUND: - (hw:2,0)"
    # disable_playback = false
    # disable_capture = false
    portaudio_playback="default"
View all 9 project logs
  • 1
    Steps
    Follow below steps to repeat the experience of this project
    • Step 7. Wiring the Robotic Arm
    NOTE: All these steps are detailed in the Logs of this project
View all instructions
Guillermo Perez Guillen wrote 07/19/2021 at 04:14 point
This project also participates in the "Supplyframe DesignLab: 2021 Hackaday Prize" contest, in the category of "Challenge 2: Refresh Work-From-Home Life".
Guillermo Perez Guillen wrote 06/28/2021 at 03:00 point
This project participates in the "Supplyframe DesignLab: 2021 Hackaday Prize" contest, in the category of "Challenge 4: Redefine Robots" and the updates will be published before the deadline.
