Step 1. Let's Get Started
A project log for GUILLENGAP Robot Arm
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System, and 2) Sorting Objects System
Guillermo Perez GuillenGuillermo Perez Guillen 06/28/2021 at 01:370 Comments
Hardware Prerequisites
Before getting started, you can check with more details what hardware I used:
Software Prerequisites
You can check what required software on my personal computer I used:
Setting Up the Hardware
Once everything is well installed on your Raspberry Pi board, You can check the versions of: npm, node and nodejs.
In my case, I had two serious problems with the configuration of my hardware and these are the solutions:
FIRST SOLUTION: to activate the pcm.speaker, I had to add a rate of 16000 in the assound.conf file.
pcm.speaker {
type plug
slave {
pcm "hw:0,0"
rate 16000
SECOND SOLUTION: My Raspberry Pi board has better audio with the "portaudio" board, so I had to activate it in the snips.toml file
[snips-audio-server]
# frame = 256
# bind = "default@mqtt"
mike = "MATRIXIO-SOUND: - (hw:2,0)"
# disable_playback = false
# disable_capture = false
portaudio_playback="default"
