Step 11. GUILLENGAP Robot Arm 2nd Version - Test
A project log for GUILLENGAP Robot Arm
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System, and 2) Sorting Objects System
Guillermo Perez GuillenGuillermo Perez Guillen 07/30/2021 at 20:300 Comments
TESTS
In the video below I show you the tests with a water bottle.
Now in the video below, the robot arm helps me unsolder a breadboard´s wire.
Finally, and as in the first version, I order the robot arm to move a box containing a lamp.
CONCLUSION
This was a good experience as I used a free tool to control my robot arm with the Alexa Echo Dot device. Also increase the functions without problems. The results were satisfactory and you can see them in the videos above.
