Step 2. Connect Sam to Your Raspberry Pi
A project log for GUILLENGAP Cobot
Collaborative Robot Arm with Artificial Intelligence, and Used as Assistant in: 1) Voice Command System & 2) Sorting Objects System
guillermo-perez-guillenGuillermo Perez Guillen 06/28/2021 at 01:540 Comments
On the command prompt of you Raspberry Pi board type ifconfig to know the IP address of this device
From your computer's terminal, you can connect to the Raspberry Pi board
Sign in through the Sam CLI Tool
