Connection scheme
A project log for CM6 - Compliant 3D printed robotic arm
Cheap, Open-source, safe, and compliant 6 - Axis 3d printed robotic arm based on Quasi direct drive BLDC drives.
petar-crnjakPetar Crnjak 09/18/2021 at 08:020 Comments
BLDC drivers are connected to connector board using modified IDC cables. More can be found in this folder: https://github.com/PCrnjak/CM6_COBOT_ROBOT under building instructions
Each distribution board is connected to 24V thru screw terminals. Also each distribution board needs to be connected to 5V and GND.
