Distribution/connector board info!
A project log for CM6 - Compliant 3D printed robotic arm
Cheap, Open-source, safe, and compliant 6 - Axis 3d printed robotic arm based on Quasi direct drive BLDC drives.
petar-crnjakPetar Crnjak 09/13/2021 at 16:260 Comments
A Connector board is used to connect the S-drive BLDC driver to the 24 power supply and to the teensy microcontroller.  They are designed to be stacked one on one with brass spacers.
