VTOL_F35_plans_sheet1_FULL.pdf
Sheet 1 of the F-35 plans, full size.
Adobe Portable Document Format - 53.29 kB - 07/06/2021 at 18:24
Preview
Download
VTOL_F35_plans_sheet1_FULL_NOGRID.pdf
Sheet 1 of the F-35 plans, full size and without the grid for laser cutting.
Adobe Portable Document Format - 45.66 kB - 07/09/2021 at 18:46
Preview
Download
VTOL_F35_plans_sheet1_A4.pdf
Sheet 1 of the F-35 plans, ready to print on A4 paper.
Adobe Portable Document Format - 45.94 kB - 07/06/2021 at 18:24
Preview
Download
VTOL_F35_plans_sheet2_FULL.pdf
Sheet 2 of the F-35 plans, full size.
Adobe Portable Document Format - 53.17 kB - 07/06/2021 at 18:24
Preview
Download
VTOL_F35_plans_sheet2_FULL_NOGRID.pdf
Sheet 2 of the F-35 plans, full size and without the grid for laser cutting.
Adobe Portable Document Format - 45.59 kB - 07/09/2021 at 18:46
Preview
Download
VTOL_F35_plans_sheet2_A4.pdf
Sheet 2 of the F-35 plans, ready to print on A4 paper.
Adobe Portable Document Format - 42.58 kB - 07/06/2021 at 18:24
Preview
Download
F35_tail_decal_left_A4.pdf
Left tail decal.
Adobe Portable Document Format - 476.08 kB - 07/06/2021 at 18:24
Preview
Download
F35_tail_decal_right_A4.pdf
Right tail decal.
Adobe Portable Document Format - 557.12 kB - 07/06/2021 at 18:24
Preview
Download
F35_tail_decal_left_dRehmFlight_A4.pdf
Left tail decal with dRehmFlight logo.
Adobe Portable Document Format - 563.33 kB - 07/06/2021 at 18:24
Preview
Download
F35_tail_decal_blank_A4.pdf
Blank tail outline to design your own decal.
Adobe Portable Document Format - 6.16 kB - 07/06/2021 at 18:24
Preview
Download
3D_parts_flat.pdf
Don't have a 3D printer? Print out this sheet and use it to cut the parts you need from 3mm plywood.
Adobe Portable Document Format - 10.22 kB - 07/06/2021 at 18:24
Preview
Download
tilt_motor_mount_X1.STL
Print 1 of these.
Standard Tesselated Geometry - 53.60 kB - 07/06/2021 at 18:24
Download
motor_mount_aileron_X2.STL
Print 2 of these.
Standard Tesselated Geometry - 49.30 kB - 07/06/2021 at 18:24
Download
control_horn_X4.STL
Print 4 of these.
Standard Tesselated Geometry - 29.18 kB - 07/06/2021 at 18:24
Download
tilt_bracket_X3.STL
Print 3 of these.
Standard Tesselated Geometry - 18.44 kB - 07/06/2021 at 18:24
Download
tilt_side_mount_X2.STL
Print 2 of these.
Standard Tesselated Geometry - 9.46 kB - 07/06/2021 at 18:24
Download
tilt_main_X1.STL
Print 1 of these.
Standard Tesselated Geometry - 2.23 kB - 07/06/2021 at 18:24
Download
tilt_bracket_horn_X1.STL
Print 1 of these.
Standard Tesselated Geometry - 27.62 kB - 07/06/2021 at 18:24
Download
