A subtle detail was the failure of transducer #3.
A new one went in but still yielded a short period of low flow, then shut down & leaked lots of water. There might be a bad screw hole leaking water.
The original transducers have lots of scale but flow like they were new. Transducer #3 got a new driver board which didn't make any difference. The leading theories are a bad cable or the transducers having to be matched to the driver boards.
A new enclosure was already conceived to move the transducers closer together. To do this, they got a common cap which would have required removing 6 farsteners to access 1 transducer. Obviously, it's not practical in a world where transducers are consumable & must be replaced 1 at a time. The mane desires would now be thicker walls to try to reduce the water leaks, possibly more transducer spacing to keep water from landing back on the other transducers, possibly a 4th transducer.
lion mclionhead
