[002] Humble Beginning Adding Numbers
A project log for rj32
A 16-bit RISC CPU with 32 instructions built with Digital and verilog for an FPGA.
rj45rj45 07/12/2021 at 22:070 Comments
Jan 3, 2021
Well, you gotta start somewhere, right?
This video is mostly introducing some of the basics of Digital. I introduce how wires work, some of the components, embedded circuits (modules), etc. Eventually I get the beginnings of a decode and execute unit going. You can see the execute unit above, and the other units are just wires really. Here's a high level diagram:
And here's the decode unit:
Pretty humble.
If you'd like to see this in video form and get the tutorial, you can watch that here:
