Miniscule WiFi Artnet DMX Node
Multi-generation Mini Artnet DMX Nodes with WiFi Capability, RDM, Pixel FX and DMX Input support. Based on mtongnz's DMX library.
As a lighting technician, I often have to run cables across walkways, moving props, or only awkward places to run a wire. Wouldn't it be nice to have a wireless solution? While there are many commercial units available using various protocols, they are either expensive or unreliable. With our product, you could have any show set up within hours! With its slim and compact design, it fits right in your pocket! With the implementation of Wi-Fi, there is no need to worry about cables. Stored scenes allow for instant playback through the web interface with nearly no latency
BOM_expanseElectronics_artNetNode.csv
BOM File (LCSC formatted)
ms-excel - 4.54 kB - 07/05/2021 at 08:52
Download
GRB_expanseElectronics_artNetNode.zip
Gerber Files for PCB Ordering
x-zip-compressed - 101.80 kB - 07/05/2021 at 08:51
Download
krauthaus wrote 07/07/2021 at 22:23 point
ATM i am trying to learn myself enough about lora; my goal is a Lora DMX Node. (Few Kilometres Distance, nice penetration of buildings, free of cost.
Maybe you are interested:)
(Main Goal: Instant remote control of locations on your hole city. it's got very cheap and you just need some nodes placed on top of some high buildings. I have not decided if I want to make a meshtastic plugin for that or if I want to go your way. :) )
