Adding a WD Timer to the Teensy
A project log for Power Analyzer based on a COTS Power Monitoring IC
The idea of this project is the development of a power analyzer based on the ACS71020 power monitoring IC.
sebastianSebastian 07/22/2021 at 11:220 Comments
When hitting "read" of the button in rapid succession, the Teensy somehow stopped working and had to be reset manually. To fix this problem, I used a Watchdog-Timer which is fed periodically and resets the teensy after 30s, if not "fed". The library used for this is the WDT_T4 library by tonton81.
The reason for the bug under load is yet to be determined.
