May the power be with you!
A project log for Goertzel Algorithm
For when you don't need a big Fast Fourier Transform (FFT) or are just to lazy to do FFT.
agpcooperagp.cooper 07/08/2021 at 03:050 Comments
Power Calculations
I have decided to drop power calculations because they cause all sorts of problems.
Just let power=amplitude*amplitude; if you really want to use it.
In the end a power calculation needs a load impedance to actually make any sense anyway.
Continuous Mode
What would be really nice is a form of Goertzel's algorithm that is continuous like the exponential smoothing function. Because of the windowing I don't think it is possible?
AlanX
