LED Flashing 555 Timer 3D Printed Circuit
The general purpose 555 timer IC. Designed with PLA & conductive filament to rapid additive manufacture. This is fully functional! It blinks
555 timer project This project is for the general purpose 555 timer IC. The base is PLA (non-conductive) while the top layers are conductive (@proto-pasta). The traces are connected according to this blog http://elecengworld1.blogspot.com/2015/11/led-flasher-circuit-using-555-timer-ic.html This is a fully functional circuit! It is aimed to be a learning kit to teach STEAM grades K-8 https://www.youtube.com/watch?v=qnT3PtjQI90 Dimensions: 30mm x 30mm x 6mm Print time is 1 hour 30 minutes *At 7%-8% mark, change the filament to conductive filament for a successful print.
Rapid circuit prototype with a 3D printer and conductive filament.
This project features a simple circuit designed to explain the working and use of a 555 timer IC.
The connection used is credited to this blog LED Flasher Circuit
The 555 timer was one of the first IC chips I learned to use in a project back when I attended community college. I learned to read the datasheet and create my first flashing LED! This is a good place to start for those new to electronics.
*I recommend reading the 555 timer datasheet to learn more!
Note: When the print is 7% to 8% complete, the conductive filament should follow. Here is a great Instructable for welding 3D filament Filament Fuser.
*I simply snipped off the colored PLA with a wire cutter, then guided the conductive filament into the 3D printer until the extruder accepted (grabbed) it.
555 Timer Project.stl
Standard Tesselated Geometry - 352.62 kB - 07/11/2021 at 01:13
Download
  • 1 × 3D Printer
  • 3 × Resistors SAT (selected at testing) I used 100k, and two 1k Ohms
  • 1 × Capacitor 1uF or 100uF SAT (select at testing)
  • 1 × 9 volt battery Any brand will do
  • 1 × 5mm LED I used blue. Color is optional
View all 8 components
View project log
  • 1
    Step 1
    After the print is complete the top layers of the board should have 3mm+ conductive filament.
    Pin 2 and 6 are connected. All other pin connections will need to be made manually.
    Place 555 timer onto 3D printed board and press firmly to make a strong connection. Careful not to bend the legs!
    1. Connect pin 4 and 8 together with a male to male jumper or wire. *tinned wire for optimization
    2. Connect LED ground leg to pin one.
    3. Connect R3 (1K ohm) to +itive lead of LED, and then to pin 3.
    4. Connect R1 between pin 6 and 7
    5. Connect R2 between pin 7 and 8
    6. Place C1 between pin 1 and 2 *-itive lead to pin 1 (for polarized capacitors)
    7. Note: Pin 5 will not be connected (this is also called floating)
    The last step is to power the circuit. 5V-9V is a good value to use for the power supply. Here I used a 9V battery and snap connector.
    Connect negative lead to pin 1. Connect positive lead to pin 8
    Please like, share, or comment. Find us on all social media! Check us out on Tindie
View all instructions
