Day Clock
Sometimes we just need to know what day it is
jonJon
This was created at the beginning of the pandemic when the two week lockdown was approaching a month and the days were starting to blend together.
For those long quarantine weeks where the days blend together. This clock uses a servo so the clock hand always points at the center of the day, it does not "sweep" through the day smoothly like a normal clock would; at midnight, the hand moves to the next day. Thanks to the gearing, this works with a normal 180 degree servo. Code is included, just update to your WiFi information!
Servo_Gear.stl
Large gear to be attached to servo
Standard Tesselated Geometry - 511.31 kB - 07/13/2021 at 15:57
Download
Clock_Gear.stl
Small gear that connects to clock hand
Standard Tesselated Geometry - 280.26 kB - 07/13/2021 at 15:57
Download
Clock_Face.stl
Single piece clock face for FDM printing
Standard Tesselated Geometry - 600.77 kB - 07/13/2021 at 15:57
Download
Blank_clock_face.stl
Clock face without text/lines for SLa + glue printing
Standard Tesselated Geometry - 32.89 kB - 07/13/2021 at 15:57
Download
Box.stl
Box holds the Wemos and Servo Wiring
Standard Tesselated Geometry - 9.07 kB - 07/13/2021 at 15:57
Download
View all 12 files
  • 1 × Wemos D1 Mini
  • 1 × MG996R Servo Any full size 180 degree servo should work
  • 1
    3D Print Components
    Print the one-piece clock face at .2mm and change the filament between layers 15/16 for an FDM printer, or print the individual components on an SLA printer and glue together.
  • 2
    Install Servo In Base
    Push the servo into the base until it hits the bottom
  • 3
    Assemble Servo Gear
    Attach the servo gear to the servo horn, then attach to the servo
View all 7 instructions
davedarko wrote 07/17/2021 at 19:19 point
that's a fantastic clock, would have been enough for most of the days :)
