Pocket NC jog controller
A project with pi pico, it makes controlling your Pocket NC much easier
Getting frustrated when doing some manual machining on my Pocket NC, I decide to make a CNC jog controller for my Pocket NC, like the ones you find on a HAAS machine. The controller has to have 2 basic functions: 1. Being able to select the axis, 2. Have a jog wheel. Also, I don’t want to make the controller only limited to Pocket NC, but be a “universal” controller, if I make a robotic arm in the future, I want the controller able to, controller. To do this I decided to use the new Pi Pico as the controller’s control board, it will communicate to the computer HID, basically act like a mouse and a keyboard. Then I have a Python script running on the computer to interpret the control’s input and translate it into action needed; in this case, licking the axis button on the Pocket NC control site.
video of the jog controller working.
  • 1 × pi pico
  • 1 × micro usb cable, 3 to 6 feet Connectors and Accessories / Telecom and Datacom (Modular) Connectors
  • 1 × hand wheel manual encoder https://www.amazon.com/gp/product/B07G9FVHM8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  • 2 × 200 ohm resistor
  • 5 × push button switch https://www.amazon.com/gp/product/B0752RMB7Q/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
View all 7 components
  • 1
    getting the files.
    go to my GitHub page and download all the files: https://github.com/George0023/pocket-nc-jog-controller
    3D print the stl file in sequence.
  • 2
    assembly
    secure led, button and jog wheel so it look at the front of the controller.
    wire up all component like this:
    solder everything.
  • 3
    getting the software ready
    the software instructions are over at GitHub, where you download all the files from.
View all 4 instructions
Mwhitehouse wrote 02/22/2023 at 18:58 • point
hi, im having trouble getting the software to work. When I run the receiver I get a bunch of errors.
