Knock Knock - User interface part two
A project log for LoRaLamp AIRQuality
A Desklamp for your "Work from Home" Desk with Air Quality Sensor, LoRa, WiFi, MQTT that reminds you to open your windows for Fresh Air
ulrichUlrich • 07/16/2021 at 19:11•0 Comments
I wa searching the other day for a different AIR Quality Sensor on Aliexpress. And Lucky me: I came across a different Sensor for the User Interface. Thsi should be an addtional sensor to the rotary knob
I was thinking if I could extend my user experience a little bit. I came across this MPU9250+BMP280 Breakout Board.
This enables the following features:
- Knocking Detection (User Action if you knock on the Lamp)
- Activate Lamp by rotation
- Deactivate Lamp be turning the head in any direction
And the good news again: Same pinout as my Air Quality Sensors that I choosed so far. So easy for stacking the sensors and quick tryouts during development.
