The first PCB have arrived.
I Ordered my PCB at JLC PCB. You may compare differnt PCB suppliers here in this overview from Hackaday.
Please choose wisely you PCB material. Some PCB manufacturers still offer lead PCBs. They are easier to solder but bad for our environment.
I choose to solder my components on my own. If your Layout turns out wrong it is easier because you are not waisting so much money
Time for fitting it into the case.
YES: IT fits perfectly fine on the first Try!
No lets try to assemble the mounting holes to see how it looks with the PMMA Cover
Outcome: Fits perfectly, even if it doesn't look like here :-)
