USB B to Micro USB Adapter PCB
A simple USB B to Micro USB Adapter PCB
Public Chat
To start off, thanks to JLCPCB for sponsoring this project and providing the pcbs I designed. JLCPCB Prototype for $2 (Any Color): https://jlcpcb.com/DYE I never have full size USB B cables when I need them but always have micro USB cables so I've made a simple adapter PCB to replace the port on my Arduino Uno. See how I desoldered the original USB port and replaced it with my adapter here: https://www.youtube.com/watch?v=c1nMM70-RdU This is a simple solution to a simple problem. No extra wires are required, the castellated pads directly solder surface mount style to the original USB pads. If this sounds useful to you, you'll find the files down below to order your own pcbs and the link to the micro usb connector used is in the component section.
usb_b_to_microsch.brd
Eagle PCB
brd - 31.62 kB - 07/16/2021 at 17:14
Download
usb_b_to_microsch.sch
Eagle Schematic
sch - 53.21 kB - 07/16/2021 at 17:14
Download
usb_b_to_microsch_2021-06-30.zip
PCB Gerbers
Zip Archive - 32.23 kB - 07/16/2021 at 17:14
Download
  • 1 × micro USB female connector https://ebay.us/zpnfMq
