Project Outline
- document the development process to include others in on the fun
- use cheap off-the-shelf parts where possible
- design all custom parts to be made with either a laser cutter or a 3D Printer
- Simply the electronics
- Write assembly instructions and make assembly videos (When the above is complete)
Russell Munro
Brian Brocken
Patrick
Hi. I have a question. Regarding the motor. The link you provided is for the real motor as in the one we should buy coz it shows a lists of motors. Also do we need to buy with the encoder or without?
