Goal Setting
A project log for VHDL/Verilog to Discrete Logic Flow
Work in progress: Flow to synthesize VHDL/Verilog code into a PCB
timTim 10/04/2021 at 19:500 Comments
As stated in the introduction, the goal of this project is to create a workflow to generate a PCB with discrete (transistor based) logic from a hardware description language file. This should happen in a reproducible and automated way, with as little user interaction as possible.
Let's get one thing out of the way first, the inevitable question of "why"? Some possible reasons:
To be a bit more specific about the goals:
