TapBadgeV2.csvKiCAD Exported BOM for all components needed!Please note: The board was designed to only optionally require the STM32, as it is not foreseeable when this chip will ever be available! All parts should be orderable from DigiKey. Comma-Separated Values - 3.16 kB - 11/01/2021 at 22:38 |
MagnetClip.stlMagnetic Clip used to hold the magnets in placeStandard Tesselated Geometry - 111.51 kB - 10/14/2021 at 14:27 |
Shell_Bottom.stlSTL File of the bottom half of the Badge. Print as a single piece, no special treatment is necessary.model/stl - 314.05 kB - 10/04/2021 at 07:36 |
Shell_Top.stlSTL File of the top half of the badge.When printing, keep two things in mind: 1) The Filament is supposed to be swapped to a clear filament after the top horizontal layer is finished, to create the see-through ring for the notification LEDs 2) Three M1.5 nuts have to be embedded within the print, so it must be paused before the top covers of the three screw mounting posts are printed. The nuts can be inserted with a bit of force (tune printer to make it snap-fit), then continue printing. Optionally sand down the front of the casing to make it smoother. model/stl - 388.66 kB - 10/04/2021 at 07:36 |
TapBadgeV2_Gerbers_Rev1.0.zipGerber Files of the completed Tap Badge PCB, Revision 1.0Zip Archive - 709.14 kB - 09/24/2021 at 21:25 |
