• Based on the SAMD51 microcontroller running at 120 MHz with 1MB of flash. (ATSAMD51J20A-MUT)
  • Bluetooth Low Energy (BLE) controllable. Send and receive data between the rocket and your phone.
  • 3 Servo Channels ( Use two for thrust-vectoring and one for other stuff like a mechanical parachute ejection system!)
  • 2 Pyro Channels capable of ingiting motor ignitors and nichrome wire. Fully PWM controllable for variable current control.
  • 1 DC Motor driver for those times you need roll control with a reaction wheel.
  • Runs on 2S and 3S LIPO batteries. 3S preferable (11.1 V)
  • Includes an arming terminal to keep you safe from misfiring pyro channels.
  • Six axis IMU (BOSCH BMI088) and Altimeter (MS560702)
  • SD Card port so you can save your data!
  • 16MB of external flash storage. Save data during flight (SD card connections can be sporadic
  • during flight due to vibrations)
