JDY-08 Breakout & Voltage Measurements
A project log for Simple, Compact Wireless Measurement
Measure, probe, and monitor voltage and current remotely!
ben-limBen Lim 07/24/2021 at 09:500 Comments
So it turns out that you can even find the JDY-08 breakout from Aliexpress, which means that every part of this project is now easily breadboard-able! This means that even if you don't know how to solder, you can also build a measurement circuit yourself.
Since this is meant for low voltage experimentation, it can only measure up to 3.3V. Using Arduino's native ADC which gives us 1024 counts (8-bits), if we increase the voltage range we can measure, the precision falls.
Maybe one way is to create a switch so that you can turn on high voltage measurement whenever you want to, although I think that might already be a feature creep.
