Going nano
A project log for Simple, Compact Wireless Measurement
Measure, probe, and monitor voltage and current remotely!
ben-limBen Lim 10/01/2021 at 18:530 Comments
The next version of the board is a 17mm x 30mm board that has the following improvements:
  1. Precision voltage reference - no matter what the input, there will be a reliable reference
  2. Change of current measurement IC - now it can measure from -0.1V to 30V.
  3. Addition of Hall Effect sensor
The Hall effect sensor is meant as a tool to wake the device - since it is so small now, it can easily be used as a monitoring device for another circuit in a semi-permanent or permanent installation. With the Hall sensor, it can be used to wake the device remotely for measurements on a as-needed basis. Since the addition of the High Voltage Element, I've not found a reason to use it, so I might remove it for something else.
Do you have any ideas about what other features that might be interesting to add? Let me know!
