HBC-56: 65C02 + TMS9918A on a backplane
HBC-56 A homebrew 8-bit computer with a backplane. Initially with a 65C02 CPU card, a TMS9918A VDP and dual AY-3-8910 audio.
Public Chat
A custom 8-bit backplane build initially running a 65C02 CPU and includes a TMS9918A VDP.
Introduction
After building a breadboard CPU and getting it to run Snake, I decided to do something different.
I'd done some coding for the Commander X16, so was interested in starting out with a 6502-based homebrew computer. My childhood machine was a TI-99/4A, so wanted to try out a TMS9918A for video output.
All source code, schematics and tools I've built for the project are available on GitHub: github.com/visrealm/hbc-56
Hardware
I've always wanted to do a backplane build and also wanted to try my have at PCBs, so started by designing a custom backplane and custom proto cards for it. The backplane consists of a 56-pin bus, hence the name: HBC-56 (HomeBrew Computer 56)
So far, I've built up 7 cards on the proto boards:
  • Three-way clock module
  • 65C02 CPU card
  • RAM/ROM card with 32KB of each
  • LCD card (with support for graphics LCD)
  • TMS9918A display card
  • Dual AY-3-8910 sound card
  • PS/2 keyboard and dual NES controller card
With help from @PCBWay Official , the cards are now being gradually replaced with custom PCB's such as this new 65C02 CPU card.
Software
I have written an initial Kernel to bootstrap the machine and help with interfacing with the various hardware modules. It is also possible to run the machine raw (without the kernel)
The project includes a number of example programs and games (Invaders, Breakout) to test out the various hardware modules. It also includes a port of EhBASIC and an Invaders clone (WIP).
All of the software is available on GitHub: github.com/visrealm/hbc-56
Emulator
To aid in software development, I have also build an Emulator for this machine.
The emulator includes support for all of the hardware modules, including the TMS9918A, the LCD card (in character LCD or graphics LCD mode), input and audio. It also includes an integrated debugger which allows you to step through disassembled code with labels.
You can try the emulator in your browser here: https://visrealm.github.io/hbc-56/github-pages/emulator
Full details on the emulator here: github.com/visrealm/hbc-56/emulator
Videos
tms9918a_vdp_v0_1_sch.pdf
TMS9918 card schematic
Adobe Portable Document Format - 174.45 kB - 12/08/2021 at 00:31
Preview
ramrom_v0_1_sch.pdf
RAM/ROM card schematic
Adobe Portable Document Format - 149.01 kB - 12/08/2021 at 00:31
Preview
lcd_v0_1_sch.pdf
LCD card schematic
Adobe Portable Document Format - 100.02 kB - 12/08/2021 at 00:31
Preview
clock_v0_1_sch.pdf
Clock card schematic
Adobe Portable Document Format - 111.30 kB - 12/08/2021 at 00:31
Preview
6502_v0_1_sch.pdf
6502 CPU card schematic
Adobe Portable Document Format - 116.27 kB - 12/08/2021 at 00:30
Preview
View all 10 files
View all 21 project logs
Joe Dimeglio wrote 04/13/2025 at 22:25 point
Awesome. I especially like the emulator, i don't think Ive seen so many chips supported in a SBC type emulator - saying that :-) how hard is it to say add support for the 6551 ACIA chip? Last question how or can you start the emulator in debug mode instead of run - is that i just have to manually add a break point on the reset vector? Thanks in advance..
Its so i can test my assembler  https://github.com/jdimeglio/SYSMON65/tree/main
Troy Schrapel wrote 04/14/2025 at 02:08 point
Thanks.
6551 shouldn't be too difficult. It already supports the MC6850 ACIA (Windows only)
There isn't a way to start paused yet. However you could insert a special $db opcode which will cause the debugger to break.
edsjac wrote 11/22/2022 at 01:42 point
Very cool design! Congratulations!
Pep3175 wrote 06/17/2022 at 18:43 point
What you have done is really impressive. Thank you for your help on Reddit with scrolling text. I think your work will help me out.
Troy Schrapel wrote 06/20/2022 at 02:15 point
Thanks. And, no problem.
bradley.bell wrote 09/30/2021 at 09:25 point
Looks nice, I'm starting something similar, and i may borrow some of these concepts
Troy Schrapel wrote 10/05/2021 at 03:55 point
Thanks, Bradley. All the best with your build.
