module size adjustment
A project log for Modular PCB origami
The unique design makes its assembly independent of frames or jigs. Use hardwires to connect a pair of PCB and fold it into the shape.
warmbitwarmbit 08/07/2021 at 15:230 Comments
I am making a bit bigger size of triangle. At the same time, the size of square, pentagon and hexagon is changed to be compatible with each other. This will take a longer time.
