Zener-Tester / LED-Tester Layout
A project log for Hack into an existing Multimeter
Using the impact resistant case of a multimeter for your electronics Demonstrated on the design of a Zener-Tester / LED-Vf-Tester
max-schnorpfeilMax Schnorpfeil • 08/03/2021 at 15:51•0 Comments
Layout is done using EasyEDA. You can view the files here.
It's a 2-layer board with 1.0mm thickness. Might go for a better 4-layer stackup in a later version for EMI purposes.
More on good stackups can be found in Robert Feranec's videos (like this).
