Version 1 putting the modules together
A project log for Reimplementing a 1 bit CPU
Learning the MC14500B Industrial Control Unit
ken-yapKen Yap 08/23/2021 at 09:540 Comments
First I had to correct errors in the modules. Then I needed a NOR gate to combine the reset button with the NOPF reset signal. In addition I have attached a clock generator, a hex instruction address display, input and output pins for the test program, and a LED on output 7.
The program simulated was the one used in the Arduino emulator:
LD 1; AND 2; STO 3; STOC 7; NOPF;
and letting the simulation free-run showed it looping through the instructions, and lighting the LED if  I1 AND I2 is FALSE; STOC 7 effectively makes the LED show a NAND.
I'll test it a bit more before posting the Logisim files, and decide what the next stage, if any, should be.
