Excellent news! Thanking to @ljmarent efforts CRISS CP/M has got the 3D printable body! It is not just a copy of the standard G738 case, it was wisely customized with the optional VESA and DIN-rail mounting options!
After it will be verified and approved design files will be published here! Thank you, Les!
Igor
