CRISS CP/M Lan Server Edition is coming. It is the best platform to build your own custom smart control system and the first real control platform based on CP/M OS! The board contains minimal set of components, for the programming it is coupled with the "rest part" of the computer. You may use any programming language available for CRISS CP/M! After the testing project will be published and described at Discord, don't forget to join!
Igor
