LAN9252-SPI adapter board design
A project log for EtherCAT servodrive
Free CoE (CAN over EtherCAT) CiA402 servodrive on STM32. For open motor controllers like ODrive, STMBL, or your next thing.
kubabudakubabuda 08/03/2021 at 20:080 Comments
Starting point was this open source project. Stripped schematic to bare minimum, based on EVB-LAN9252-SPI. Left only SQI PDI, then minified board area. Two layers, almost all components on single side for easier assembly and embedding into target devices.
lan9252spi_rev1_top
lan9252spi_rev1_bottom
Adapter board, first revision, straight from KiCad.
IBOM can be found here
Looks good. Board came out similar to EasyCAT Pro. Breakout header is compatible, additionally alongside it has full SQI exposed. Also EEPROM chip is THT in socket for simple swap if ESI flashing goes wrong and bricks device. Now forward to board house of choice, and wait for PCBs to arrive.
Spoiler alert: it worked good enough for what I needed, for practical use you better wait for something better or buy EasyCAT PRO
