LAN9252-SPI board, second revision
A project log for EtherCAT servodrive
Free CoE (CAN over EtherCAT) CiA402 servodrive on STM32. For open motor controllers like ODrive, STMBL, or your next thing.
kubabudakubabuda 08/06/2021 at 20:210 Comments
In the meantime some things to correct were found in first revision of SPI adapter.
- QFN is annoying to hand solder. TQFP package was selected, there is enough space on PCB
- changed magjacks to cheaper ones
- EEPROM  switched from THT in socket to SMD package: less bulky, cheaper. Swapping chip from board bricked by bad config was never needed. No matter how bad was configuration, new one could be upload over EtherCAT every time.
lan9252spi_rev2_top
lan9252spi_rev2_bottom
IBOM can be found here
Design is ready to order and test, but due to performance benchmark results different approach was selected
