Hackaday.io Hackaday.io
Sign up Log in
EFEKTA PWS ZIGBEE
Wireless Mini Plant Watering Monitoring Sensor (capacitive soil moisture sensor), compatible with ZigBee networks (ZIGBEE2MQTT)
andrew-lamchenkoAndrew Lamchenko
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3k views
0 comments
16 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
  • 2021 Hackaday Prize
View Gallery
3k
0
16
6
Team (1)
  • andrew-lamchenkoAndrew Lamchenko
Join this project's team
  • EFEKTA PWS
  • Z2M Supported devices
completed project
MISC
cc2530 ZIGBEE Zigbee2mqtt Plant Watering 2021hackadayprize Soil moisture measurement sensor capacitive soil moisture
This project is submitted for
  • Hackaday.com Tip Line
  • Challenge 3: Reimagine Supportive Tech
This project was created on 08/04/2021 and last updated 4 years ago.
Starting from
$18.22
Buy on Tindie
diyberk has 289 orders / 11reviews
Ships from Russia
Description
Soil moisture measurement sensor project . Low power consumption, very small device. Built on the basis of SoC CC2530 (EBYTE). A simple and very cheap alternative to existing commercial solutions (MI FLORA). There are only 10 components, the assembly time is 10-15 minutes. A great solution for exploring mesh networks and IOT.
Files
2_2477.STL
Standard Tesselated Geometry - 4.34 MB - 08/11/2021 at 18:06
Download
2_2450.STL
Download
1.STL
Standard Tesselated Geometry - 7.63 MB - 08/11/2021 at 18:06
Download
3.STL
Standard Tesselated Geometry - 796.66 kB - 08/11/2021 at 18:06
Download
Project Logs
Collapse
  • Сase for a CR2477
    Andrew Lamchenko • 08/11/2021 at 18:04 • 0 comments
    A case for a CR2477 battery(950mA)has been added to the project.
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "EFEKTA PWS ZIGBEE", please tell us the reason.
Send message
Remove Member
