Hackaday.io Hackaday.io
Sign up Log in
Liftmaster Gate WiFi hack
Using an ESP8266 to add wifi functionality to my gate so i can open and close it over MQTT
daniel-johnsonDaniel Johnson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 4
    • View all
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
645
0
2
2
Team (1)
  • daniel-johnsonDaniel Johnson
Join this project's team
  • Source Code
ongoing project
ESP8266 mqtt Gate wifi Node-RED automatic opener
This project was created on 08/05/2021 and last updated 5 years ago.
Description
I used an ESP8266 to add WiFi functionality to my gate so that i can open and close the gate over MQTT. This in conjunction with my freshtomato flashed routers, I am able to automatically open and close the gate when my phone connects to the router located at the gate. I am using node-red for the backend presence detection and gate logic.
Files
Device Activity Flow.json
node-red device activity flow
JavaScript Object Notation (JSON) - 52.27 kB - 08/05/2021 at 00:53
Download
Gate Flow.json
node-red gate flow
JavaScript Object Notation (JSON) - 9.45 kB - 08/05/2021 at 00:53
Download
Gate Gerber.zip
Zip Archive - 44.69 kB - 08/05/2021 at 00:40
Download
Gate.zip
Eagle schematic and board
Zip Archive - 605.30 kB - 08/05/2021 at 00:39
Download
Project Logs
Collapse
  • Video demonstration
    Daniel Johnson • 08/05/2021 at 00:52 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Three-inverter ring oscillator with fourth gate as a buffer
Project Owner Contributor
Ring Oscillators: Fairchild DTL 949
dana-myersDana Myers
The 2017 Hackaday Prize
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This will develop into an educational platform.
IO - The Inside Out Cardboard Computer - bis
dr-cockroachDr. Cockroach
An old-school style electronics lab to learn about transistor-based logic gates.
Transistor Logic Gates Lab
deftcoyotedeftcoyote
The 2016 Hackaday Prize
A series of ternary logic gates and higher level components implemented in the real world.
Tern - Ternary Logic Circuits
mechanical-advantageMechanical Advantage
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Liftmaster Gate WiFi hack", please tell us the reason.
Send message
Remove Member
