Usage
The lamp has switch to turn it on/off and encoder with button for interacting with its menus.
How it was made.
Just a plastic box, foam board plate, lamp holder, relay module, wire with switch, screws/nuts, some hot glue and electronic modules.
Software
The following diagram represents the state machine used in device's program.
Check out github repo for sources.
Danya0x07
Great project. Appreciate you including the STls, schematics, pinout, and source repo. Makes it easier to follow along with your work. Good stuff :100:
