Yield Rate Update
08/28/2021 at 07:36 • 0 commentsAfter my initial two attempts at soldering these boards I was confident I would end up with a higher yield rate >50%.
Apparently I was wrong.
After soldering 11 boards I ended up with 2.5/11 working ones which is a yield rate of ~22%.
The .5 had problems with the level shifter but is otherwise OK.Lessons learned:
- soldering 0.4mm pitch WLCSP is hard
- proper stencil alignment and paste application is mandatory
- proper soldering equipment is a must (hot plate + hot air is too inconsistent)
- blaming the equipment for your mistakes is always possible
In short this means that these boards will not be available in my tindie store for a little while. I will have to fix the aperture for the stencil in some places and get a proper hot air oven (probably a modded toaster).
I am still happy the layout of the board was correct on the first try and, as usual, I learned a lot in the process of breaking things. I have also added a picture of my testing jig for your enjoyment.
Hackaday Prize 2021
08/21/2021 at 14:54 • 0 commentsToday I saw on the hackaday blog that there is a running contest for which this project might be eligible. I've updated the projects details with a "Why I made it" section and added two pictures with application examples for the module.
Hardware Update
08/19/2021 at 18:52 • 0 commentsToday the PCBs arrived! Yay!
I soldered two of them which was kind of tricky since the components are really, really small.
The first one I soldered was a fail. I could see solder bridges under the ADP5360
chip. The second one (the one with the pin headers) turned out nicely and both I2C devices
showed up.
Except for a few missing capacitors that went flying somewhere and the one board with shorts (which I
kind of expected since it was a first for me) I am quite happy with the results up until now.
I have enough of the expensive components to solder 9 more which I will hopefully be able to do
this weekend.
