Assembly Draft # 1 ( DAV5 V3 Spectrometer)
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 11/15/2016 at 12:480 Comments
The above picture shows the 8mm/10x focal lens assembly, which also can accomodate the 32mm plossl lens assembly also (attaches to the 38mm mounting coupler.)
