Alternative 32mm Focal Lens Assembly for the DAV5 V3 Spectrometer
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 11/23/2016 at 18:470 Comments
Alternative focal lens assembly 32mm plossl lens can be used in place of 8mm focal lens assembly, I have already tested this on my prototype, and the results are posted below;
