Addendum To Log # 44
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 01/14/2017 at 12:450 Comments
From the specifications sheet for the JDEPC-05 cmos sensor;
To find a theoretical MTF curve for a sensor, it is necessary to know three characteristics of the sensor: the active sensing area, the area comprising the sensing area and the interconnection and support structures ("real estate"), and the total number of those areas (the pixel count). The total pixel count is almost always given. Sometimes the overall sensor dimensions are given, from which the real estate area can be calculated. Whether the real estate area is given or derived, if the active pixel area is not given, it may be derived from the real estate area and the fill factor, where fill factor is the ratio of the active area to the dedicated real estate area;
Where
  • the active area of the pixel has dimensions a×b
  • Discussions
