Added Filter Slot to Cuvette Holder (DAV5 V3 Spectrometer)
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 02/02/2017 at 14:010 Comments
I designed the slot on top so the filter slips down and has a good fit, it does not need to be removed, even for absorption spectra, I may design a filter holder in the future in which you can place the filter in it and insert the whole assembly down the slot for easier removal.
