*UPDATE* Change made To The MCU/ATmega1284 REV B
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 03/10/2017 at 09:330 Comments
I removed the 1st breadboard strip I had in place as my terminal junction, and used this configuration instead. This makes more sense and gives me room to employ the necessary 100 ohm resistors and other terminals.
